VASP modifes IMAGES in NEB calculation and how to deal with?
phydig
Post by phydig »
Dear all:
When performing NEB calculation I specified IMAGES=2 and created four subfolders named
00, 01, 02, 03, respectively.
But I found that only 01/ contained output files, so I doubted that the IMAGES may be changed in the executing.
I added some tracking statements to the source file and recompiled VASP. Rerunning VASP in my system by typing:
bsub -q rms -n 16 -e err.1 -o log.1 ~/bin/vasp_NEB
The information in output files told me that VASP had really modified the IMAGES.
Source file was modified like this: (in main_mpi.F, line 81)
IF (IMAGES>0) THEN
write(tiu6,*)"IN main_mpi.F call M_divide! IMAGES= ", IMAGES !ADD
CALL M_divide( COMM_WORLD, IMAGES, COMM_CHAIN, COMM, .TRUE. )
write(tiu6,*)"Returning from M_divide,IMAGES= ", IMAGES !ADD
Output information was:
IN main_mpi.F call M_divide! IMAGES= 2
Returning from M_divide,IMAGES= 1
IMAGES was changed! So endpoints of images were not 00/POSCAR, 03/POSCAR, and became 00/POSCAR, 02/POSCAR.
As indicated by this information generated from neb_init(chain_init, calls neb_init)
(Some output statements were added to the source file)
POSCAR: SYS:Pt100(2x2)+Nb+Ob 01
positions in cartesian coordinates
No initial velocities read in
CHAIN: Read ICHAIN 0
CHAIN: Running the NEB
Call neb_init
NEB Params: spring, spring2, efirst, elast, ispring, spower:
-5.00000000000000 -7.00000000000000 -103.462770000000
-102.541359000000 2 1.00000000000000
images= 1
POSCAR: System: Pt100(2x2)+NO Upright 00
positions in direct lattice
velocities in cartesian coordinates
idir=images+1 = 2
POSCAR: SYS:Pt100(2x2)TST 02
Current node is: 1
Return from neb_init
I have analyst the reason why IMAGES was changed to be 1. It was passed as a parameter to the subroutine M_divide
IF (IMAGES>0) THEN !(main_mpi.F line 81)
and was modified by this statement in subroutine M_divide
IF (NPAR >= COMM%NCPU) NPAR=COMM%NCPU
Because COMM%NCPU here was equaled to 1. But I requested 16 CPUs, Why?
I specified NPAR=16 and IMAGES=2, following are top lines of OUTCAR:
vasp.4.6.9 24Apr03 complex
executed on True64 date 2006.12.09 17:56:06
running on 1 nodes
each image running on 1 nodes
distr: one band on 1 nodes, 1 groups
Why running on 1 nodes and each image running on 1 nodes?
I suppose above lines should be:
vasp.4.6.25 17Sep03 complex
running on 16 nodes
each image running on 8 nodes
distr: one band on 1 nodes, 8 groups
My system is:
Compaq Tru64 UNIX V5.1A (Rev. 1885); Tue Mar 25 12:25:36 CST 2003
This is sigma-x, a Compaq AlphaServer SC V2.5 system
LSF version is:
Platform LSF AlphaServer SC V2.5 UK1, Feb 21 2003
Thanks a lot for your kind consideration.
It sounds like lsf has only given the job 1 processor instead of 16. This would explain the output that you see, wouldn't it?
If this is the case, it is not a problem with the neb - rather something with the queuing system or mpi.
Can you run an regular (non-neb) calculation on many processors?
Are you using an mpi version of vasp, i.e. built with -DMPI?
phydig
Post by phydig »
Thank you very much for your reply.
It seems that only 1 processor performing the task. But when I type bjbos command, 16 CPUs are listed:
JOBID USER STAT QUEUE FROM_HOST EXEC_HOST JOB_NAME SUBMIT_TIME
37318 phydig RUN rms sigma-x0 sigma-x2 *ijob ./v5 Dec 10 09:36
sigma-x2
sigma-x2
sigma-x2
sigma-x3
sigma-x3
sigma-x3
sigma-x3
sigma-x8
sigma-x6
sigma-x6
sigma-x6
sigma-x4
sigma-x4
sigma-x5
sigma-x5
This time I submitted my task by typing: bsub -q rms -n 16 -e err.10 -o log.10 mpijob ./v5
Where v5 is the MPI version of VASP with NEB implement. And my MPI version is COMPAQ MPI V1.96
When I compiled VASP, I did use the –DMPI directive. But I am not sure the line
BLAS = -lcxml in the original Makefile should be modified to be
BLAS = -lcxmlp
For the system gives me the information below each time when I login.
Compaq Extended Math Library is available on this machine.
Users can link your routines with -lcxml option (-lcxmlp for parallel).
I tried both cases and found both versions of VASP can run.
When running an regular (non-neb) calculation on many processors, the top lines of OUTCAR are :
executed on True64 date 2006.12.07 09:51:32
running on 1 nodes
The task was submitted by typing bsub -q rms -n 16 ~/bin/vasp
This problem confuses me. Thanks a lot for your kind help.
Since you get the same problem with a regular vasp calculation, this is probably not a problem with our neb routines. The problem is likely related to the fact that you are running vasp directly, instead of using mpirun. For your calculations, you should try replacing
~/bin/vasp
with
mpirun -np 16 -machinefile (some_file_that_you_get_from_pbs) ~/bin/vasp
To debug this, you can also try running this second command directly, using a machinefile containing a list of the machines you want to run on.
phydig
Post by phydig »
Since on my system it provides command mpijob instead of mpirun. And the reference manual tells me that the parallel and serial jobs should be submitted in the same way. I tried to submit my task like this:
bsub -q rms –n 16 prun ~/bin/vasp
Then the top lines of OUTCAR were:
executed on True64 date 2006.11.19 08:03:30
running on 16 nodes
distr: one band on 1 nodes, 16 groups
But the test of NEB method on my system has not been performed because the computational resource is not available now.
phydig
Post by phydig »
The parallel version of VASP can be compiled successfully on my system.
However, when running VASP will abort immediately after it is started due to “LAPACK: Routine ZPOTRF failed!”
I have fixed this problem by lowering the optimization level of mpi.F.
Since the NEB method essentially requires parallelization May this will lead to a decrease in efficiency?
If it is true, how to improve the efficiency when performing the NEB calculations?
Thanks for your kind consideration.
I don't think you will see any decrease in performance by changing the optimization level in mpi.F. Most of the time is spent in the blas/lapack and fft routines. If you use efficient versions of blas/lapack, such as goto, acml, or mkl, and possibly fftw for the fft routines, you will have an efficient binary.
phydig
Post by phydig »
Thank you very much!
