Effect of MAGMOM on energy barrier
Posted: Fri May 09, 2025 5:38 pm
Dear VTST users and Prof. Henkelman,
I have been working on Single atom catalysts on a surface. We want to see the energy barrier of decomposition of K2S. So reaction will be
*K2S ---> *KS + *K
where * represent that system (K2S, KS and K) has attached on the surface.
Usually, I relaxed my system with spin-polarization, which is a bit more accurate than without spin because of relaxation of higher number of degree of freedom.
On relaxing both the initial and final structures show different magnetic moments of Fe atom.
So, Initial I started with same magmom as I have provided to relaxed structures.
But I am getting some weird energy barrier (attached image with_spin_and_six_images.png)
Also, I repeated the same calculation with eight images (attached image with_spin_and_eight_images.png)
Finally, I have did the energy barrier calculation without spin (attached without spin.png)
Note: all the calculation are conveged with EDIFFG = -0.05
I have read some of previous post, which suggest that we can tune the magnetic moment of images by performing one cycle single self consistent calculation. My questions are:
Q. What magnetic moments should I provide images as initial and final structures have different magnetic moments?
Q. Any suggestion of MAGMOM tag on energy barrier calculation will be highly appreciated.
thanks and regards
Mukesh Singh
*K2S ---> *KS + *K
thanks and regards
Mukesh Singh
