Image interval will set to be equal when a new image added?
cenwanglai
Post by cenwanglai »
I have make a CNEB run with 4 images, and found the first imgae (in 01/) seen to be the TS. So I add a new image between the 00 and 01. So, the interval between images will set to be equal in the following converging process?
Re: Image interval will set to be equal when a new image add
If you use the climbing image, the images on either side of the saddle will be equally spaced at convergence.
